s2000 trunk leaking
Old Jul 21, 2017 | 06:01 AM
patt_stayys2k's Avatar
Default s2000 trunk leaking
good moring my name is patrick mcguire and i am a proud owner of a 2006 honda s2000 ap2 i am having a little bit of water in my trunk im am reaching out for help on how to fix this issue and and to stop the issue
Old Jul 21, 2017 | 06:24 AM
EOE's Avatar
EOE
Hey,
1) Take all of the trunk lining out so you can see only the bare metal
2) With soft-top closed, pour a gallon+ of water on each side down the soft top drains
3) If you see a stream of water run into the lowest point of the trunk (which I did) your drains are clogged
4) Clean the drains
Old Jul 21, 2017 | 06:56 AM
thank you for the reply. i did that the other day and i pored water on both sides of the soft top and it worked but as i made my way to the trunk it was damp not really water but you can see the dry water spots, from my understanding there are two drain holes in the trunk under the lining not sure on how to clean those if you have any suggestions ? i also spoke to a friend of mine who also has a ap2 and he said drill little holes in the trunk witch i dont feel comfertable about but if i have to to stop the water i guess i dont have a choice
Old Jul 21, 2017 | 08:46 AM
HarryD's Avatar
If you fix this properly, you do not have to drill holes in the trunk.
Follow the previous instructions, use warm-hot water with the top up. Get under the car. You should feel with your hands under the door where the drains exist out. Take a stick or zip tie or something stiffer and shove it up the hole to clear any blockage.
Secondly, pop the trunk and see if it's leaking from another spot -- for me, I had clogged drain holes (accessible from under the car), as well as water being redirected under my quarter panel into my trunk lining (accessible with the trunk interior removed). I had to remove the little bracket adjacent the trunk, clean and seal the area, and reinstall the bracket.
dkatzfey
Apr 30, 2017 05:24 PM
don.cs.smith
Apr 20, 2016 06:07 AM
lolS2K
Sep 29, 2015 08:16 AM
macr88
Interior
Jan 14, 2010 06:18 PM
tlee1234
May 2, 2009 07:12 AM
