>> S2000 Valve Adjustment, Step-By-Step
Old Nov 29, 2002 | 09:39 AM
Pinky's Avatar
In all honesty valves probably should be adjusted at 50K just to make sure all is well. Only before that if you KNOW that they are noisy or spend lots of time up between 7K and 9K. And I mean ALOT! Numerous track days/auto-x's etc where most if not all of your time is in VTEC and at the upper end of VTEC.
I did mine at about 45K and felt next to nothing. All valves were within spec.
Old Nov 29, 2002 | 12:06 PM
Gernby's Avatar
Former Sponsor
I've adjusted mine several times in the 16K miles I've had my '02. I think it is a good idea to adjust them right after the car is broken in, since the valve clearances will change as the valves seat.
One thing I did on my last adjustment was to reduce the clearances by .001", or so, since they are already fully seated, and I will adjust them more often than the suggested service interval. I wouldn't say that it makes a noticeable difference, but it increases lift and duration by a tad.
If it wasn't already mentioned, it is REALLY important to measure the clearance between the valve spring retainer and adjuster screw, and NOT between the roller rocker and cam lobe (as with some Honda's). I made this mistake on my first adjustment.
Destiny2002,
Those pictures are copy righted by Helms. Someone (you, S2KI, etc.) could get in trouble for posting them...
Old Nov 29, 2002 | 12:18 PM
Destiny2002's Avatar
edit
Old Nov 29, 2002 | 03:28 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Love step 36 "Check over the job, and be sure all the tools are still accounted for". I wonder if a set of feeler gauges shredded in the camshafts would be covered under warranty. Great post!
Old Nov 30, 2002 | 09:44 AM
edit
Old Dec 12, 2002 | 05:12 AM
Squeezer's Avatar
You don't have to take out the spark plus for this job to be performed. that step should be omitted. Also the assembly the adjustment screw is screwed into can be pushed up and down with your finger, you should put that the adjustment should be performed with these screws at rest (in other words make sure they are pushed down and not pushed up).
very good write up though!
Old Dec 12, 2002 | 07:37 AM
edit
Old Dec 13, 2002 | 06:11 AM
Squeezer's Avatar
Originally posted by Destiny2002
The spark plugs are removed to eliminate engine compression in the cylinders, which makes it possible engine over by hand with the wrench on the crankshaft bolt and land at TDC for each cylinder.
I'm not clear on what the second part of your comment is describing... Please clarify.
Thanks,
Paul
i adjusted my valves with the spark plugs in and didn't have any trouble turning the crank. sure I had to pull on the wrench a little harder, but nothing my muscles couldn't handle.
The set screw rests in that little round thing that is connected to a pivoting mechanism. you want to make sure that mechanism is pushed down (at rest) instead of being pushed up.
Old Dec 13, 2002 | 07:52 AM
edit
Old Jan 6, 2003 | 09:16 AM
1a-race's Avatar
Banned
where is mechanicsburg in relationship to philly or pittsburgh. would you mind teaching me with my car how to do this?
