S2K DEAD?
Old Jul 16, 2006 | 10:18 PM
topekoms's Avatar
Default S2K DEAD?
car wont start.
checked all that i can
checked spark plugs
checked fuses
checked coils
checked for gas
checked battery
even tried jump starting
please help
Old Jul 17, 2006 | 05:01 AM
Ek9's Avatar
Ek9
Banned
Won't start or won't crank? It's not the same thing. If it won't crank it can only be a couple things, clutch interlock and push button or starter.
If it won't start then you need to find what's missing. It needs spark, fuel (and proper fuel pressure) and compression.
1) For spark, I'd probably pull a coilpack and plug, ground the outer part of the plug and have some one crank it and see if there's spark.
2) For fuel, I'm not sure exactly. You need 40+ PSI at the fuel rail. Just having fuel in the tank isn't enough. If it was me, I'd hook up a fuel pressure tester.
3) For compression, when it cranks does it crank normal or faster then normal ? Compression tester too.
jonkou888
Feb 3, 2017 03:48 PM
Lou-AP1
May 30, 2015 08:28 AM
Lookatmy240
Dec 15, 2009 01:47 PM
jonkou888
Oct 3, 2009 01:22 PM
s2kjb
Nov 16, 2006 07:06 PM
