s2k is making a strange sound.
Old May 26, 2012 | 09:24 PM
Angelfire's Avatar
Default s2k is making a strange sound.
Hi guys, im having this problem with my S. at low speeds its making this high pitched screeching sound. almost like the sound cars make when the brake pads are completely gone but i am not even pressing the brakes. i think the source maybe the car is low on break/ or steering fluid but not sure. it is coming from inside the front wheel well, if anyone has had this problem please guide me in the right direction, thanks a million for any insight on this
Old May 26, 2012 | 11:21 PM
S2K-F8's Avatar
Well I can guarantee that you are not low on power steering fluid! Our cars have Electronic Power Steering (EPS)
Old May 27, 2012 | 01:36 PM
Adionik's Avatar
Check your belts or if something is rubbing
Worst case, add more power steering fluid.
Old May 28, 2012 | 06:49 PM
Angelfire's Avatar
ughh i was hoping it would be a simple fix or something minor like low on ps fluid, btw i have a 2004 AP2, or do ALL s2k's has EPS? the sound is killing me. i installed a berk exhaust this past weekend (sounds fantastic) and this minor dilemma is ruining the sound of the whole driving experience...
Old May 28, 2012 | 07:04 PM
305AP1's Avatar
does it get worse when you actually press the brakes? also our intakes make a pretty high pitched noise at certain throttle positions .
Old May 28, 2012 | 10:38 PM
S2K-F8's Avatar
Yes, all model year S2000's have EPS
Old May 30, 2012 | 05:43 PM
Angelfire's Avatar
305ap1; it is generally when the car gets moving. when i come to a complete stop at a traffic light for example the noise stops and when i use the brakes it stays the same it doesn't get any louder. i think it maybe the break pads that are too worn and metal is being contacted on metal but if this was the case then it would only get louder when i brake and i doubt it is the air intake... i run my intake with the lid off and when i had the OEM exhaust installed all i could hear was it sucking in air louder, i know it is definitely coming from inside the wheel well just dont know whats causing it.
ok thanks F8, also does it matter if your steering fluid is on or just a tad bit above the minimum line? mine is at the minimum line..
this problem is driving me crazy, i am going to take out the front tires and run a thorough inspection of everything when i get some time.
Old May 30, 2012 | 05:57 PM
Btrthnezr3's Avatar
Maybe you have a pebble stuck between rotor and pad? I've heard of such on the fit forum.
Old May 30, 2012 | 07:42 PM
xviper's Avatar
The S2000 has NO steering fluid.
PS. I had my avatar picture 37,000 posts ago.
Old May 30, 2012 | 07:47 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by xviper
Welcome back OG
Ecclesium
May 4, 2010 11:26 PM
SUH
Aug 28, 2007 01:55 PM
labratodd
Feb 17, 2004 03:40 PM
MarkS2K
Jan 31, 2001 01:18 PM
