SC More Midrange Boost
Old Nov 9, 2003 | 07:22 PM
TwoFourty's Avatar
[QUOTE]Originally posted by Darksyde
Old Nov 9, 2003 | 09:51 PM
KYS2000's Avatar
Old Nov 10, 2003 | 01:46 AM
honda9krpm's Avatar
you took the word right out of my mouth too
This should work.
Custom make an electronic control boost wastegate for the sc.
T-piece it between the BOV and the intercooler (on the vortech system).
It's going to be expensive though.
How big is the turbo wastegate anyway?
Old Nov 10, 2003 | 04:42 AM
Darksyde's Avatar
[QUOTE]Originally posted by KYS2000
Old Nov 10, 2003 | 04:44 AM
Darksyde's Avatar
This should work.
A turbo wastegate takes up some room. I mentioned the POV because you can adjust it without electronics and it's cheap, $120 give or take.
Old Nov 10, 2003 | 10:52 AM
Pakisho's Avatar
A friend of mine has a similar setup on a supercharged taurus sho. I mentioned it before once. He is using an 18psi pulley on the car, but has it setup so that anything over 15psi will be vented to the atmostphere.
I talked to Chad about this at Comptech, and he said they couldnt use a BOV due to CARB getting all pissy about venting air directly to the atmosphere. The way the comptech is currently setup, its a self contained unit.
A centrifugal blower on a small displacement engine is a terrible approach to midrange, anyway.
Old Nov 10, 2003 | 11:05 AM
Nobody's Avatar
So will venting to the atmosphere screw anything up?
Old Nov 10, 2003 | 11:24 AM
mxt_77's Avatar
Why would CARB get pissy about venting intake air directly to the atmosphere? It's a bit different to vent exhaust gasses to the atmosphere (like a wastegate might do) because exhaust gasses would have all the nastiness that the eco-friendly types want to have passed through the catalyst first. But, the intake air is just air. It hasn't been mixed with fuel yet. I don't see why they would have a problem venting that.
Old Nov 10, 2003 | 11:29 AM
infinitebass's Avatar
Banned
Yes, no one cares about venting a BOV to the atmosphere, even CARB.
Blake
Old Nov 10, 2003 | 12:28 PM
honda9krpm's Avatar
[QUOTE]Originally posted by Pakisho
