SC Pulley Size
Old May 13, 2019 | 08:28 PM
Tempest161's Avatar
Default SC Pulley Size
Hoping this is the right area to post this and I am asking here because Kraftwerks has been no help. Main question is how small of a pulley can I go on my Supercharger? Looking for recommendations and I really am not wanting to add anymore to current setup which I have listed those specs below.
02 S2K
Comptech Dual Exhaust
Ballade Sports Header With Wide Band 02 Sensor
Kraftwerks 30-94 SC 100mm 7rib Pulley
Skunk2 4Bar Map
Radium Fuel Rail with Radium Pressure Regulator and Radium Dampener
Grams 1000cc Injectors
Radium Catch Cans
Doctronic ECU
Thank you in advance!
Old May 13, 2019 | 10:04 PM
pizzai69's Avatar
Hi,
I am in a situation very similair to you, and we talked about it recently here :
https://www.s2ki.com/forums/s2000-fo...hoice-1188978/
You can use this calculator to estimate the smaller pulley you can put, to respect the SC max rpm:
https://www.philanthropy.gr/rotrex/rotrex-calculator/
My C30-94 kit is from TTS Performance with a 125mm crank pulley and I have a 105mm SC pulley. This limits me to 8800 rpm regarding the C30-94 max rpm limit (or 9000 rpm with a little overspin)
I don't know the crank pulley size of your KW kit ??
Radfords2k
May 31, 2009 04:46 PM
j66
Sep 23, 2006 04:48 AM
johninator
Jul 23, 2006 03:47 PM
Salaska
Jun 30, 2004 09:19 AM
bgbfflochp
May 10, 2004 02:53 PM
