screeching sound on start up
Old Oct 19, 2010 | 10:14 PM
cpx3mbp's Avatar
Default screeching sound on start up
Hey guys, I have a loud screeching sound from the engine bay when I start up the car. I have pretty much isolated it to the serpentine belt but I suspect the tensioner pulley bearing may need replacing as well. I am planning to replace the belt with a goodyear gatorback belt and looking into input for whether I should also replace the tensioner pulley or the whole tensioner assembly as well. Any thoughts? Thanks in advance.
Old Oct 19, 2010 | 10:47 PM
R3DS2K's Avatar
start with the belt. if then noise is gone. leave it. if it doesnt go away. replace the whole tensioner. the pulley alone wont really do much
Old Oct 20, 2010 | 08:45 AM
cpx3mbp's Avatar
that makes sense, thanks for the advice
Old Oct 20, 2010 | 09:01 AM
EagleDon's Avatar
Have replaced both the tensioner pulley (not the whole tensioner) and the idler pulley. This cured the screeching sound. Also running a Gator belt.
Old Oct 20, 2010 | 10:06 AM
s2k dre's Avatar
I had the same issue and it was the starter making noise.
Old Oct 20, 2010 | 10:53 PM
R3DS2K's Avatar
hahai forgot that the pulleys have bearings that can cause noises. im so used to replacing corolla belts and complete tensions cuz the tensions would fail
Old Oct 26, 2010 | 07:28 PM
cpx3mbp's Avatar
replaced the belt and the sound has not come back since. thanks again
Aliminator
Aug 17, 2012 04:15 PM
hotknives
Oct 4, 2010 08:11 PM
black2000
Nov 8, 2008 10:34 AM
jdmgpw04
Sep 17, 2008 01:18 PM
Squeezer
May 29, 2004 08:57 PM
