screw behind door handle
Old Jul 23, 2003 | 05:48 PM
ankuse's Avatar
Default screw behind door handle
are their any tricks to removing and reinserting this screw, had alot of trouble getting 1 off, and when i put in the new speaker i couldn't get it back in all the way, its like solid and just won't turn, and I wasn't succesful in removing the screw for the driver's side door panel yet, i don't want to strip it.
any suggestions
thanks
ankur
Old Jul 23, 2003 | 07:20 PM
xviper's Avatar
It has to go in at exactly the correct angle to get a straight shot at the screw hole. If you are just a bit off, you are actually screwing it in BESIDE the hole.
Old Jul 24, 2003 | 03:50 AM
CoralDoc's Avatar
The plastic handle trim can shift forward and backward a bit. Like xviper said, make sure the screw is lined up properly and it should screw in smoothly.
Old Jul 24, 2003 | 02:41 PM
dlq04's Avatar
What you are trying to align with are the two yellow colored objects behind the plastic. Sometimes it helps to use something slender like a thin Phillips screwdriver (or a drift, if you have one) to align the holes on the handle with the holes on the yellow objects, before inserting the screws.
Old Jul 24, 2003 | 03:53 PM
ankuse's Avatar
sorry, i probably was not clear enough, i was refering to the one screw behind the door lock area not the actual handle.
thanks again
ankur
isthisusernameavailable
Mar 20, 2019 04:25 PM
Saki GT
Sep 12, 2017 07:47 PM
dlq04
May 22, 2012 07:39 AM
RL428
May 12, 2010 06:33 AM
JamieS2K
Oct 20, 2004 07:28 AM
