Second Gear Grind
Old Mar 17, 2005 | 07:27 PM
juncoma's Avatar
Thumbs up Second Gear Grind
I have a new S2k with 300 miles. I have detected some difficulty putting the car in second gear during cold starts (in Ohio). After driving 5-7 miles the problem goes away. Today I drove another new S2k at the dealer and found the same defect. Is this typical? Does it go away after breakin?
Old Mar 17, 2005 | 10:48 PM
Bane's Avatar
This is normal. Doesn't seem to go away after the break-in (my car has over 10,000 miles now... I just changed the transmission fluid last night and it still does it).
I think others will agree with me as well. I think all model year S2000s do it.
Just shift slower and at lower RPM when the car is cold to minimize the "crunch".
Old Mar 18, 2005 | 06:29 AM
S2000RAT's Avatar
I have a 01 and mine did it from day one.
Old Mar 18, 2005 | 10:00 AM
joe9k's Avatar
mine does it too. 2002 with 5000 miles. Its fairly common for S2ks. After warm up mine goes away.
Old Mar 18, 2005 | 10:12 AM
Nickfromny's Avatar
00-02 had issue, it was/is being addressed under TSB-058 warrentee. Thought 03-05 had no 2nd gear grind. Check library for all TSB's. They are the factory know issues that are being addressed.
Old Mar 18, 2005 | 10:38 AM
Silver S2k4's Avatar
its normal, let the car warm up before driving. I let it get to 4 heat bars and then take off.
Old Mar 18, 2005 | 12:22 PM
cyber_x's Avatar
Sounds normal to me. My '02 has done this for a long time, now at 76k miles plus change, it still does it.
Changing to GM Synchromesh Friction Modified in the transmission helped some in my case, but did not completely eliminate the behavior.
ChristianJayBaril
Jul 31, 2012 12:50 AM
jd2131
Jan 26, 2006 08:13 AM
mrc8251
Dec 19, 2002 11:27 AM
edasaurus
May 27, 2002 09:23 AM
98TypeR#21
Nov 18, 2000 06:53 PM
