Secondary O2 sensor
Old Apr 4, 2008 | 09:33 PM
roku's Avatar
Default Secondary O2 sensor
Hi,
on my MY 05 I get sporadic CELs when I use a berck testpipe even it features the built in O2 sensor fix. My concern is that I might have power loss as the O2 sensor fix seems not to work robust on my car, the ecu might get inconsistent data and therefore the ecu would switch in a safe mode or control the a/f ratio in the wrong way.
Having this in mind I disconnected the secondary O2 sensor now. By this I always have a cel. However I think the ECU could handle a disconnected sensor better than one that delivers wrong data. Any thoughts on this?
Thanks,
Robert
Old Apr 5, 2008 | 09:30 PM
pemex70's Avatar
I wouldnt. I think it can create problems down the line that will be costly. Better to attack the problem instead of ignoring it.
Dont let that bump turn into cancer.
Just my opinion.
Old Apr 6, 2008 | 09:50 AM
roku's Avatar
Just my opinion.
Just a matter of view. I don`t want to ignore the ECU gettting invalid data from insufficient sensor fix of the test pipe so I attack the problem by deconnecting the secondary O2 sensor cable.
Robert
Old Apr 6, 2008 | 10:30 AM
RISLAR's Avatar
Why dont you put on another antiplug fowler on it?
Old Apr 6, 2008 | 01:00 PM
s2kdiggler's Avatar
yea best bet is to fix it right now and then!
Old Apr 6, 2008 | 06:51 PM
LostMotion's Avatar
I believe the only point of the sensor is to tell you if the cat is working or not. So it won't matter at all if it's plugged in or not. However, the sensor's life will be lessened so it may be better to take it off.
Old Apr 9, 2008 | 10:24 AM
roku's Avatar
[QUOTE=carrera4,Apr 6 2008, 06:51 PM]I believe the only point of the sensor is to tell you if the cat is working or not.
Old Apr 9, 2008 | 10:49 AM
MikeyCB's Avatar
I would go buy an anti-fouler and try that out. At least that way you'll actually know when you have a REAL CEL.
It's my understanding the the 2nd o2 sensor is there just to confirm proper cat functioning as well.
Old Apr 9, 2008 | 11:01 AM
Ahnold's Avatar
With either O2 sensor disconnected, the ECU will always run in open loop.
unowned
Apr 11, 2021 08:19 AM
Pacman123
Oct 5, 2016 06:01 PM
Deliverance
Aug 4, 2010 07:17 PM
kinetica
Sep 12, 2006 06:40 PM
