Secondary O2 sensor stuck
good tips, thanks guys. Don't plan on doing many more O2 sensor changes but I've got the 22mm handy now. I didn't go nuts when I re-intsalled the sensor but I did apply a bit of anti-seize to the threads, hopefully next time its easier. The head is a bit rounded off on two of the points but I think I'll be OK.
I checked O'Reilly's and Home Depot for the O2 sensor socket, neither of them had it. I heard stories about them flaring out though, so I may stick to the wrench.
just a 22 will be fine. you wont have room for that anyways if you ever have to change the primary. as jordanksartell mentioned just a tap it with a rubber mallet and it should break loose. i have never used wd40 or pb blaster eitheron my o2 sensors.
