Sensitive clutch & ABS light intermittent
Old Feb 25, 2011 | 05:59 AM
ILowNslowI's Avatar
Default Sensitive clutch & ABS light intermittent
ok so my clutch is sensitive to extreme, I have played with the adjustment rod a few times & still the same. It seems like I have a throw of only 3-4in for disengage/engagement...even with adjusted rod. There has not been one person who has driven my S who has not killed it the 1st time(including myself) I have to let it our veryyyyyy slow & just barely give it any gas at all...the car peels out too easy & sometimes I dont think its the tires screeching & its the clutch? if anyone can point me to WWWTTTTFFFF is the deal with this mofo id greatly appreciate it!
ABS light...this comes on sometimes, but always goes back off after I shut it off & restart, sometimes its 5min of driving, sometimes 1hr...how can I get this checked, I can get ahold of a scanner & have tried to search code but nothing?
Old Feb 25, 2011 | 07:00 AM
Round 3's Avatar
Did you check your clutch fluid? Might have air in the system. Go Bleed it until its clear and check back. Unless your pressure plate is messed up.
Old Feb 25, 2011 | 07:41 AM
ILowNslowI's Avatar
did check the fluid, its full...I will look into bleeding the system & see if this helps...
thanks!
Old Mar 1, 2011 | 01:56 PM
ILowNslowI's Avatar
alright so I did the clutch bleed this morning...the pedal it self feels a bit better but still the same sensitivity...my car just hit 82k & I would assume its still OEM clutch?
Anyone other ideas???
Old Mar 4, 2011 | 07:53 PM
ILowNslowI's Avatar
bump
walter22
Jul 9, 2014 03:17 PM
jimnasty23
Oct 9, 2010 02:19 PM
oyitzpreston
Jun 24, 2010 01:30 PM
loftust
Jan 31, 2010 09:06 PM
p-p-porkchop
Nov 24, 2007 01:40 PM
