Sensor Fuzziness (erratic TPS, Coolant sensor ...)
Old Apr 2, 2010 | 04:06 AM
kaissi's Avatar
Default Sensor Fuzziness (erratic TPS, Coolant sensor ...)
I recently installed the AEM EMS V2... The first problem I faced is "fuzziness in almost all sensors"
Here's what happened:
I have a Euro version S2000 2004 AP1 F20C2. I tried the AEM and the display was erratic for the coolant temp and TPS.. very fuzzy between 1-4% at idle and the coolant is always fuzzy between 90-93 like crazy... and if you push on throttle the fuzziness increase...
also cranking is bad.. when I try to crank the car it takes like 5 cranks to run..
I have a friend of mine who has a Euro Spec AP1...I tried the AEM on his car.. everything was stable...
So it's my car...first I thought maybe because it's a Euro version ?!? but if sensors are different, there should be an offset in values ..not fuzziness?!!?
I assume it's a grounding issue, maybe the car's earthing is not good enough, though on stock ECU.. the car is running perfect ?!?!?!
chtmatthew
Feb 13, 2019 05:58 AM
redboosteds2k
May 29, 2018 04:54 AM
joefish1298
29
Jul 20, 2012 05:51 PM
kaissi
Apr 3, 2010 04:55 AM
kaissi
Apr 2, 2010 02:57 AM
