Is this a serious issue???
Old Mar 9, 2004 | 09:44 AM
S2000_rider's Avatar
Default Is this a serious issue???
I dropped my car off to have the brakes pads changed and fluid flushed...When I came back in he was still working on the car. Unfortunately, I noticed he had already changed the front pads...THEN he flushed the brakes...THEN he installed the rear pads.
What possible damage could have been done if any? Also, can someone also briefly explain why all pads have to be changed BEFORE the flush?
Thanks,
Old Mar 9, 2004 | 10:36 AM
heffergm's Avatar
Huh?
Flushing the brake fluid has absolutely nothing to do with changing the brake pads. They're not related in any mechanical fashion whatsoever. You can certainly do one without having done the other.
Relax (and be thankful you knew enough to bring your car to a mechanic).
Old Mar 9, 2004 | 10:40 AM
wortham's Avatar
actually, that maintenance really isn't all that painful. pull out a helms and be maticulous about following the steps. i'm not saying this from a experienced mechanic's point of view cuz before my S, i had only changed the oil in a car once before.
Old Mar 9, 2004 | 11:16 AM
spider's Avatar
It doesn't make a difference which is done first. The only thing I can think of is, if you replace the pads after the flush, you might need to readjust the brake reservoir fluid level.
Old Mar 9, 2004 | 02:56 PM
[QUOTE]Originally posted by spider
Old Mar 9, 2004 | 03:23 PM
xviper's Avatar
[QUOTE]Originally posted by S2000_rider
Old Mar 10, 2004 | 03:29 AM
heffergm's Avatar
Old Mar 10, 2004 | 05:44 AM
dreamgetter1's Avatar
^ Good point I'll remember to do that when I do my brakes! Thanks.
Old Mar 10, 2004 | 09:22 AM
[QUOTE]Originally posted by xviper
winter5470
Feb 20, 2015 12:25 PM
AndyThomason
May 29, 2007 01:58 AM
mrkim019
Sep 26, 2005 06:52 PM
gerryk
May 13, 2003 05:12 PM
marclw
Sep 10, 2002 05:04 AM
