service S2000
Old Oct 23, 2013 | 09:23 AM
bhchase's Avatar
Default service S2000
Sorry for the stupid questions , but I want to learn how to service my S2000. 2004 with 90,000 miles. Just bought it.
1. Change oil. Got that covered.
2. change transmission fluid. What type and weight?
3. change rear end fluid. What type and weight. Does it have posi traction ?
4. Change anti freeze. How do you drain it. what type anti freeze, does it have an aluminum block ?
I have ordered a manual, but haven't got yet.
Thanks for you help
Old Oct 23, 2013 | 11:21 AM
iamxpl's Avatar
check the DIy section. its got everything you need.
1. check
2. amsoil MTF syncromesh or honda MTF
3. amsoil severe gear 75 90.
4. check DIY section billman has a procedure for this. use honda OEM coolant.
while youre at it:
check spark plugs, cabin filter, valve cover gakets ( including plug seals ) get a valve adjustment done if you havent already. re torque axle nut to spec, check your sub frame bolts, bleed clutch and brake fluid and grease your shifter along with the clutch slave cylinder DIY.
that should be a good place for you to start.
BTW ALL IN THE DIY section
Old Oct 23, 2013 | 07:57 PM
bhchase's Avatar
Thanks !! Didn't know about the DIY. Its great.
Old Oct 28, 2013 | 04:42 AM
takeshi's Avatar
Also available online. Don't overlook Google (second hit using the keywords 2004 S2000 manual):
http://techinfo.honda.com/rjanisis/p...404MAINIDX.pdf
GetRektd
Feb 27, 2016 05:23 PM
Isduy
Oct 8, 2013 06:44 AM
Tsuchiya
Feb 23, 2009 01:17 PM
msm_s2k
Nov 14, 2006 02:53 AM
