Shall this hose be connected?
Old Apr 20, 2015 | 04:34 PM
lpcome's Avatar
Default Shall this hose be connected?
Just got a 2002 AP1 and found out the highlighted hose was disconnected. Instead the port was closed by a plastic cover.
Car is running OK.
Shall I connect this hose? Curious why it did not cause any problem when it's disconnected?
Thanks!
Old Apr 20, 2015 | 06:20 PM
zeroptzero's Avatar
Did they disable the air pump system that is on your car ? That hose feeds the air valve on the air pump system which in turn feeds air into the exhaust ports on start up for emissions reasons. The previous owner may have disconnected the air pump system and it is likely running an Izzy bypass setup. Nothing wrong with that as long as it was done correctly.
Old Apr 20, 2015 | 06:46 PM
lpcome's Avatar
Thx bro for the quick reply. I agree with you. After searching some diagrams it shows the hose is related to the air pump. This car has a K&N CAI not sure it was done during that time?
Actually I remember not long ago there was a CEL on and read the code it was P0410, which is related to the secondary air pump. I cleared the code and so far it has not come back. If the connection is correct then the CEL will not come back right?
Old Apr 20, 2015 | 07:02 PM
zeroptzero's Avatar
You might have some parts missing from the system, or the air pump system has been eliminated. If they had an Izzy kit to properly bypass the air pump system you wouldn't get a CEL. There a numerous parts and hoses to the air pump system, so it could be a lot of things.
Beyond_Redline
Jul 15, 2012 11:22 AM
camuman
Dec 4, 2008 10:12 AM
gravitykills
Aug 28, 2008 06:34 PM
