EPS test gone bad
Old Apr 18, 2015 | 07:23 PM
t-o_double_d's Avatar
Default EPS test gone bad
too tired tonight to go searching through forums and see if this will be an easy fix.... but if anyone knows feel free to chime in....
a buddy of mine lost his power steering.. we were working on my car today to add a hitch to it and in some downtime he swapped our EPS modules to test if his module was bad... we are both MY05 and the modules were the same part number.. after he threw my EPS module in his car power steering returned for a minute but before he could test drive the light on his came back on and lost power steering again.. after putting my EPS module back I got his AIDS and I lost power steering...
So if anyone knows what to do that would be greatly appreciated... otherwise tomorrow after an autox I will be forum hunting to figure this out,,,
Old Apr 18, 2015 | 08:21 PM
MM3Kwolik's Avatar
Anytime an EPS module is replaced or at least paired with a different rack, you must relearn the rack to that module and vise versa. The steering angle and torque sensors save to the module so it knows when you're turning and when you're driving straight so it knows when/how much assist to give.
Sorry to say, but now you've gotta reprogram your car as well. Should've done your research first, would've saved you some money and a trip to the Honda Dealer.
Old Apr 20, 2015 | 07:37 PM
well good news... didn't have to go to the dealer.... connected pins 4 and 9 on the obd2 connector and did the 45 degree steering angle to the left trick and voila I instantly got my power steering back.... hopefully this will help some poor soul at some time...
Old Apr 20, 2015 | 08:29 PM
MM3Kwolik's Avatar
I know that method doesn't always work. Yours may have worked for you simply because that module was actually tied to your car at one point. Either way, glad it worked for you and you were able to avoid the stealership.
DarkWingS2K
Sep 9, 2012 09:23 PM
tcl
Aug 22, 2011 03:30 PM
WashabiS2K
Oct 20, 2009 06:03 AM
WashabiS2K
Nov 6, 2007 10:59 AM
