Shift Rattle
Old Jan 17, 2010 | 05:05 PM
js2k2005's Avatar
Default Shift Rattle
my shift knob tends to shake to the extreme. The vibration is really bad and when ever i step on the clucth to shift gears, the gears go in really rough. As to be scrapping something.
On the other hand clutch grabs fine, the RPMS dont drop at all.
So i was wondering if any would be able to tell me if this are sings of a bad clutch master or slave cylinder.
Someone told me it could be the fly wheel.
Anyway i hope someone can give there input on this and thank you for taking the time.
Old Jan 17, 2010 | 08:05 PM
MasterForce's Avatar
well my shifter shakes too. im sure shifter vibration is normal. as far as the roughness have you changed you tranny fluid recently?
Old Jan 18, 2010 | 01:29 AM
js2k2005's Avatar
yes, probably like 5,XXX ago. The clutch was changed probably like 30,XXX. for and ACT street clutch. The fly was left stock.
Old Jan 18, 2010 | 05:30 AM
fatjoe10's Avatar
Check the engine mounts...
Old Jan 18, 2010 | 06:53 AM
dammitjim's Avatar
Maybe. How is the level of your clutch fluid? When was the last time you changed it? Any leaks at either cylinder under the car or near the clutch pedal?
The knob shaking and the difficulty shifting may be two different problems.
Old Jan 18, 2010 | 12:39 PM
js2k2005's Avatar
well both started around the same time, but i will check and report on what i see.
Old Jan 18, 2010 | 12:44 PM
dammitjim's Avatar
I'd pull the shifter lever and make sure nothing is broken or loose in there. You can regrease it while you're in there.
dougcee
Dec 13, 2010 04:40 PM
davidh99
Oct 21, 2010 07:08 PM
StormTroopinAP2
Mar 21, 2010 06:30 AM
ihavenosn16
Jul 12, 2007 09:05 AM
smalls777
Aug 2, 2006 03:36 PM
