shifter occasionally gets kicked out of gear...
Old 11-22-2008, 05:24 PM
silvers2k2.0's Avatar
Default shifter occasionally gets kicked out of gear...
Anyone else have this problem?
it rarely ever does it, but I don't like it doing it at all.
anyone have any idea why it's doing this, and anyone have any idea how much it would cost to have made right?
Old 11-22-2008, 06:49 PM
mlc
mlc's Avatar
How many miles are on the car?
You might want to start with changing the MTF first and see if that helps.
Most people go with the Honda MTF and it does seem to help.
Kevin
Old 11-23-2008, 05:36 AM
buzz944's Avatar
i have the same problem???
44,000 miles
bought it used
Old 11-23-2008, 11:22 AM
s2kftw's Avatar
is it a random gear each time it kicks out? or is it the same gear the shifter gets kicked out each time?
Old 11-23-2008, 09:59 PM
buzz944's Avatar
mm 1st gear (once, but i guess it was due to not fully inserting the gear)
& 2nd sometimes if i dont keep my hand on the knob
Old 11-23-2008, 10:49 PM
S2KenC's Avatar
On 2004 and early 2005 model, there's a TSB (Technical Service Bulletin) for popping out of 2nd gear under deceleration while in gear. The TSB # is 05-009.
I had mine fixed under warranty.
05-009
Transmission Pops Out of 2nd Gear
SYMPTOM
The transmission intermittently pops out of second
gear on high RPM deceleration.
CORRECTIVE ACTION
Replace the countershaft 1st gear and the 2nd
gear set.
PARTS INFORMATION
First Gear:
P/N 23421-PCY-010, H/C 7596869
Second Gear Set:
P/N 23432-PCY-316, H/C 7596893
REQUIRED MATERIALS
Honda Manual Transmission Fluid
(1.7 quarts required per vehicle):
P/N 08798-9016, H/C 4928271
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 213205
Flat Rate Time: 8.2
Failed Part: P/N 23432-PCY-316
H/C 7596893
Defect Code: 03214
Symptom Code: 03701
Old 11-24-2008, 08:31 AM
It's done it with 1st, and 4th that I remember - it seems like there were other gears that did it also.
Old 11-24-2008, 11:17 AM
44,000 miles
bought it used
Mine has about the same mileage on it...
Old 11-24-2008, 04:01 PM
mlc
mlc's Avatar
Has the MTF been changed in the car? Start with the basics. Change the MTF and see if that helps the issue. There are many here that have just changed the fluid and the problem went away. Here is a DYI https://www.s2ki.com/forums/index.php?act=S...22&t=565855&st= . Its easy to do yourself and it only cost about $12 for the MTF.
Try it.
Kevin
Old 11-25-2008, 09:50 AM
I think I will.
I wanna get my hands dirty more with this car than with previous cars I've owned.
Quick Reply: shifter occasionally gets kicked out of gear...
