Shifting into Second
Hey I was wondering if it is normal for the rear end of a MY02 to kick out one way or another when shifting into second. Could this be a problem or is this normal?
I agree its very fun.. Last night however my car kicked about 7 ft to the right shifting and I didnt shift at redline- shifted at 8400 but wow had to over correct..It may be the tire pressure I need to check that out..Is there anything you can do to prevent the kick..
just keeep it to the floor
and steer through it
i find that when you let off the gas the car tends to slide out more
and it always seems to slide to the pass side
with exact tire press. +/- 1 psi
and steer through iti find that when you let off the gas the car tends to slide out more
If a tire is low on one corner, It will sea saw when you pitch back on acceleration or dive on brakes.
