Shifting into Second
Old Nov 15, 2006 | 04:01 PM
mxt_77's Avatar
Originally Posted by WashabiS2K,Nov 15 2006, 04:30 PM
hey you guys, i was always wondering.. if the rear wheels are mis-aligned, could that also result in a kicking out of the rear while redlining>shifting
Yes. But that would be something you check after you check your tire pressures.
Old Nov 15, 2006 | 04:03 PM
mxt_77's Avatar
Originally Posted by 05berlinas2k,Nov 15 2006, 04:51 PM
i find that when you let off the gas the car tends to slide out more
and it always seems to slide to the pass side
with exact tire press. +/- 1 psi
Check your alignment.
Sounds like you might have a bit of toe-out in the right rear. Although, some amount of lift-throttle oversteer is to be expected.
Old Nov 16, 2006 | 01:23 AM
RACER's Avatar
Originally Posted by wazzurp,Nov 15 2006, 12:33 PM
Last night, my car kicked about 7 ft to the right and I didnt shift at redline- shifted at 8400 but wow...
Is there anything you can do to prevent the kick...
How bout driving school
Old Nov 16, 2006 | 01:33 AM
SpitfireS's Avatar
Yes I do!
Old Nov 16, 2006 | 07:38 AM
wazzurp's Avatar
I have been to driving school at mid-ohio drove both the S2000 and the TSX through autocross and then the TSX on the track, I know how to drive thanks..I was just wondering if there was any problems that associated the kick to the right side when shifting at or before redline..
Old Nov 16, 2006 | 12:34 PM
RACER's Avatar
Wet road, uneven tire pressures, out of alignment
Old Nov 16, 2006 | 01:18 PM
GranPrix's Avatar
Hasn't the solution been posted several times already??
Old Nov 16, 2006 | 01:27 PM
mxt_77's Avatar
I dunno, but I think he might want to try checking his tire pressures.
Old Nov 16, 2006 | 01:57 PM
SilverDC2 AP1's Avatar
must be that mad vt3c torque. lol.
also check if you endlings on your swaybar are good and the bushing if you have a woobling sway it will react like you can't imagine.
Old Nov 16, 2006 | 02:00 PM
s2kshift9k's Avatar
this is one of the most FAQ's
