Shock replacement
Old Aug 5, 2014 | 05:09 AM
deepbluejh's Avatar
Question... are you replacing them because you want an upgrade or because they are worn out? If they are worn out, what symptoms are you having?
Old Aug 5, 2014 | 06:17 AM
vtec9's Avatar
Originally Posted by redlineracing
Maybe go for a used CR set or maybe the orange Koni's.So the Yellow is not a direct fit?
\rlr
Carolina
The shaft diameter is several mm larger and doesn't fit through the OEM top hats and dust boots. They need to be drilled out to ~12mm. Not a big deal, but a deal nonetheless.
Apex1.0
Oct 25, 2016 09:18 AM
K20iVTEC
Dec 4, 2014 07:00 PM
umair
Jul 9, 2014 01:15 PM
