short shifter
i recently purchased a short shifter from someone else on this forum. its the axialflow you can get from the ricks site. anyways, after i installed it i was running through the gears and noticed that you no longer push down on the stick to get it into reverse. you go all the way to the right and down and its in reverse now (where sixth use to be). is this how its suppose to be or did i over tighten the allen screws? i'm pretty sure i had the torque wrench set to the correct settings. someone please help me out. thanks.
Jonathan
Jonathan
Originally Posted by s2kjimmybass,Apr 27 2006, 08:49 PM
i recently purchased a short shifter from someone else on this forum. its the axialflow you can get from the ricks site. anyways, after i installed it i was running through the gears and noticed that you no longer push down on the stick to get it into 6th. you go all the way to the right and down and its in sixth now. is this how its suppose to be or did i over tighten the allen screws? i'm pretty sure i had the torque wrench set to the correct settings. someone please help me out. thanks.
Jonathan
Jonathan
I am not even sure it is possible to shift into sixth while pushing down on the shifter, so I'm thinking I must not understand your question. Can you provide a little more detail?
yeah, there was one that came on it when i got it from another member. is that what is causing the problem? is it not suppose to be there? i had questioned it before when i didnt see the spacer on the shifter on the installation instructions.
Originally Posted by s2kjimmybass,Apr 27 2006, 10:00 PM
i'm definetly an idiot. replace the words sixth with reverse in my first comment lol in fact, i'll fix it right now
makes sense now
