short shifter
Old Apr 27, 2006 | 05:49 PM
s2kjimmybass's Avatar
Default short shifter
i recently purchased a short shifter from someone else on this forum. its the axialflow you can get from the ricks site. anyways, after i installed it i was running through the gears and noticed that you no longer push down on the stick to get it into reverse. you go all the way to the right and down and its in reverse now (where sixth use to be). is this how its suppose to be or did i over tighten the allen screws? i'm pretty sure i had the torque wrench set to the correct settings. someone please help me out. thanks.
Jonathan
Old Apr 27, 2006 | 06:07 PM
vtec9's Avatar
wait .. what? what do you mean push down.. like going into reverse?
Old Apr 27, 2006 | 06:09 PM
Sideways's Avatar
Ouch, never push down unless you want reverse.
Old Apr 27, 2006 | 06:28 PM
Project22a's Avatar
You mean you had to push down to get into 6th before you even had the short shifter?
Something is really wrong here...
Old Apr 27, 2006 | 06:32 PM
RED MX5's Avatar
Originally Posted by s2kjimmybass,Apr 27 2006, 08:49 PM
i recently purchased a short shifter from someone else on this forum. its the axialflow you can get from the ricks site. anyways, after i installed it i was running through the gears and noticed that you no longer push down on the stick to get it into 6th. you go all the way to the right and down and its in sixth now. is this how its suppose to be or did i over tighten the allen screws? i'm pretty sure i had the torque wrench set to the correct settings. someone please help me out. thanks.
Jonathan
Jonathan, I'm confused too. The stock shifter and the AxialFlow shifter both work the same way, and the only time you are supposed to push down on the shifter is when you want to engage reverse. You pull to the left of center for first and second, let the shifter self-center for third and forth, and push to the right of center for fifth and sixth. You push down, to the right, and back, to engage reverse.
I am not even sure it is possible to shift into sixth while pushing down on the shifter, so I'm thinking I must not understand your question. Can you provide a little more detail?
Old Apr 27, 2006 | 07:00 PM
i'm definetly an idiot. replace the words sixth with reverse in my first comment lol in fact, i'll fix it right now
Old Apr 27, 2006 | 07:11 PM
Stratocaster's Avatar
I have heard of this from one other. He over tightened it and got the same results.
Old Apr 28, 2006 | 04:24 AM
SC_Highlander's Avatar
Are you running any rubber spacers between the transmission and the retaining collar (the piece with the 3 bolts through it)?
Old Apr 28, 2006 | 05:02 AM
yeah, there was one that came on it when i got it from another member. is that what is causing the problem? is it not suppose to be there? i had questioned it before when i didnt see the spacer on the shifter on the installation instructions.
Old Apr 28, 2006 | 05:15 AM
vtec9's Avatar
makes sense now
