Shudder
Old May 27, 2011 | 10:14 PM
2003AP1's Avatar
Default Shudder
I read a few threads about this and I still have not read any legit soultions for this.
My problem is as follows:
When driving as I begin to stop I down shift to say 2nd and then before actually coming to a complete stop once I press the clutch in the motor shudders dips low in rpms and then returns to normal. All of this is a matter of about a second. Sort of like I slowed down too much for the gear and the car is about to stall. (However I am going fast enough for that specific gear) I know it isnt clucth related because even in neutral I can sometimes get the same effect. If I sit there and just blip the throttle to about 2000 rpms when it comes back down it dips low and then is fine. I am curious to know what it could be. I have a 2003 with about 35k miles. I have a clean air filter and clean throttle body. At fist I thought maybe my clutch was getting hung up, but once it started happening in neutral I knew that was no longer a possibility. I know a few people have had this happen, so I am just wondering has anyone here been able to fix the problem? Or are we all just living with this minor problem?
Thanks, Tom
Old May 27, 2011 | 10:45 PM
Weasel497's Avatar
Mine does this too, but only when the AC is on.
Old May 28, 2011 | 12:25 AM
SOL1D's Avatar
From what i remember reading on threads, this was a commmon thing among s2000's, try searching it should come up that alot of people experience it. One thing I remember reading was if you push in the clutch closer to 1k or closer to where it idles it won't do it, but if u push in the clutch at a higher rpm it usually dips down below idle and shudders and shots back up to normal idle.
I know my s2000 does it, but yea search it I remember there being a number of threads of people asking if it was normal, just seems to be a s2000 thing.
Old May 28, 2011 | 12:28 AM
Carbon Blue's Avatar
clean behind the throttle plate and clean out the IACV
Old May 28, 2011 | 06:14 AM
whippets2k's Avatar
https://www.s2ki.com/s2000/topic/386...-stalling-etc/
Here is the post from the DIY section...
Old May 29, 2011 | 02:52 AM
2003AP1's Avatar
Seems like trial an error kinda thing haha thanks
Clone
Feb 5, 2007 10:25 PM
backman_66
Dec 4, 2006 07:57 PM
chuhsi
Dec 1, 2006 09:02 PM
Friday03
Oct 6, 2003 06:30 PM
tenblade2001
Dec 16, 2002 11:31 AM
