Single most important monitoring point for FI applications?
Old 03-18-2004, 06:58 AM
gropos's Avatar
Default Single most important monitoring point for FI applications?
Hi, All.
YASQFA (Yet Another Supercharger Question From Andrew):
What is the most important single bit of data for monitoring the proper functioning of a supercharger setup (or any FI setup, I guess)?
After thinking about it, my guess was Air-fuel ratio, since it is too lean of a mixture that leads to all sorts of problems, no?
I've had other people say that Fuel Pressure is more important, but doesn't it really all boil down to a proper fuel-air mixture? Even if the Fuel Pressure is ok, that doesn't guarantee a proper AFR ratio I don't think.
Based on the above thoughts, I'm thinking a wideband O2 sensor with a display (e.g. one of those PLX units) might be the single and most important monitoring device I could get for an FI application. (not saying that other data is not useful, just that this is probably the most important).
Please let me know if you think I'm full of it!
...Andrew
Old 03-18-2004, 07:02 AM
redsound's Avatar
if i were going FI, i'd get:
Oil Pressure guage
Fuel Pressure
Boost gauge
Wideband A/F gauge
and mayyyyyybe an EGT gauge for back-up.
Old 03-18-2004, 09:28 AM
gropos's Avatar
yes, I'd get all of those, too (or rather will at some point). Just musing about which is the most critical.
...Andrew
Old 03-18-2004, 09:32 AM
redsound's Avatar
[QUOTE]Originally posted by gropos
Old 03-18-2004, 12:38 PM
bigpurp's Avatar
Oil Pressure guage
Fuel Pressure
Boost gauge
Wideband A/F gauge
, although not necessarily in that order.
Old 03-18-2004, 01:03 PM
mtm584's Avatar
egt's and oil pressure
Old 03-18-2004, 01:04 PM
dave22's Avatar
Is an EGT gauge really nessecary for an supercharger?
Old 03-18-2004, 01:29 PM
gropos's Avatar
Hm.. interesting. I know that oil pressure is a good thing to have, but is it really more important than knowing if you are running lean (ie - an AFR readout)? about EGT I know less. Exactly what does a too-high EGT reading mean? is that also an indicator of lean-ness?
...Andrew
Old 03-18-2004, 04:25 PM
duff0000's Avatar
E.G.T is more turbo oreinted, Since turbos opertate at a much hotter temperature then superchargers. EGT's help you properly tune the car and also let you know when to get off the gas or turn down the boost, 1600F for a couple of seconds could melt pistons and could mean that you are running to lean.
Old 03-19-2004, 07:55 AM
S2K1's Avatar
I am getting my UR turbo kit installed on Monday, and I already have an A/F Ratio Guage and Oil Pressure and was going to pick up a Boost and EGT gauge today, but didn't think about Fuel Pressure, thanks.
Quick Reply: Single most important monitoring point for FI applications?
