Slave Cylinder
Old Nov 15, 2012 | 08:15 AM
starrman's Avatar
Default Slave Cylinder
My service manual says apply grease to the boot and slave cylinder rod...but it does not say how much? I took it apart and greased it, but the "catchy" feeling has returned again. I don't want to put too much, but guessing I did not put enough. Anyone know how much?
Old Nov 15, 2012 | 08:19 AM
g.guess88's Avatar
I would like to know too! Have the same problem. I just used my finger to scoop up some and smeared on it, it was fine for a day or 2 now it's back. Do I have to super saturate it?
Old Nov 15, 2012 | 08:56 AM
speakeasy2009's Avatar
Billman knows he just did mine...
Old Nov 15, 2012 | 09:13 PM
2003AP1's Avatar
A finger full should be good, what kind of grease are you guys using?
Maybe that is the reason? I use a nice amount of silicone paste, since I didnt have the Urea stuff.
Mine has been fine so far, only been 2 months though.
If I find that it starts acting up again I am just going to break down and buy the Urea grease from the dealer.
Old Nov 15, 2012 | 10:16 PM
kluux1291's Avatar
The same thing is happening to me. I've done it twice now, and it has returned for the second time in a row in less than 2 weeks. I'm using "Honda Super Hi-Temp Urea Grease" too.
I grind down the ball, then fill the fork cup and slave cylinder piston cup with grease and install if anyone wants to know.
Old Nov 16, 2012 | 03:01 AM
starrman's Avatar
I didnt grind it, but used some fine grit sandpaper to make it smooth. Its not that big of a job, but would like it to last.
Sent from my Motorola Electrify using Tapatalk 2
Old Nov 16, 2012 | 03:07 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
-grind off nipple
-put slave rod in a drill, spin polish with sandpaper till it shines like chrome
-using INDUSTRIAL application adhesive grease (not wheel bearing grease), liberally lube ball end
-Disengage fork momentarily, and grease FORK TIPS. you will need to reach in with a coat hanger with grease on it to do this.
-re-assemble and enjoy for years.
Old Nov 16, 2012 | 03:45 AM
starrman's Avatar
Thanks Billman, I was hoping you would jump in on this! Putting it in a drill...would have never thought to do that, thanks again.
Old Nov 16, 2012 | 08:54 AM
zeroptzero's Avatar
On the inside of the slave rod boot just put a small thin coating, they say to lube the slave rod shaft but I see no point in that as it doesn't touch anything , though I did put a small bit on there. Then of course the ball end and I put some in the corresponding hole on the fork, the excess will just ooze out , no biggie. I used Honda Hi-temp grease which I had hanging around from use in other applications.
Old Nov 16, 2012 | 09:35 AM
g.guess88's Avatar
Sorry dumb question what does it mean to put it in a drill??
