Slight misfire - but not throwing a CEL
Hi Guys, I've read thru the misfire threads here which are extremely helpful. Mines a MY04 with just 60K miles on it. But only 6K miles in the past 7yrs so its been sitting in the garage a lot!
It's running good & idling appx 900rpm, but not as smooth as I think it should. At idle get a slight "skip" every 30 secs or so. When pulling hard under acceleration, it also occasionally misses 1 or 2 times, slight but noticeable to me. So far I am not getting any CEL. My OBD scan with Blue Driver shows no codes or pending codes. I did a TB cleaning and also cleaned and oiled my K&N filter first - no improvement.
Next I'm going to start with the likely suspects spark & fuel. The Denso plugs have been in 7 years but only have 6K miles, I'm going to pull those out first to take a peek and run a compression test. Will probably switch back to NGK's. Not sure how to test the coils.
I will also pull the injectors and have them tested & cleaned at RC Injector. Fuel pressure, filter, bad gas etc I will also look at. Any other likely suspects I should look at? Thanks a ton in advance.
I recently discovered some oil on the coilpack of cylinder 4 (car threw a misfire cylinder 4 code). So obviously, I would have to replace the spark plug seals. Should I replace the coil packs too while I'm at it?
Year 2000, 130,000miles, car is in good mechanical shape otherwise.
100-125k'ish is the minimum time I've gotten on my Accord and S2000, separately, before one coil pack started to fail. But definitely a failure before 200k miles, at least in my experience.
And +1 for BIllman, I had a phantom coil pack on my AP1 which had similar symptoms as yours (and no CEL).
Very very hard to say.
My AP1 had a coil pack drop completely dead at 145k miles. It’s odd that it happened the ONE TIME I lent my GF the car at the time to drive 20 minutes to work. Replaced with 4 new AP2 packs.
I also have a customer with 280k on the original AP1 packs.
Thanks!
