Smell clutch after launch....
Old Jan 27, 2005 | 05:05 PM
oOweEe's Avatar
Default Smell clutch after launch....
i was on a empty straight away with no car in sight and decided to have a little fun....
I started driving manual not long ago and i decided to try to launch. i didnt push it hard at all.... i only reved to 3 4ish. Anyways after a really weak launch.... probably cant even consider it to be a launch but, after i slowed down, i smelled my clutch burning and the smell finally went away after 10 min or so.... is this normal???
another question:
are you suppose to drop the clutch fast? sry! im a manual tran newbieee
thanx!
Old Jan 27, 2005 | 05:13 PM
Woodson's Avatar
Yes it's normal to smell your clutch after abusing it.
Old Jan 27, 2005 | 05:21 PM
Clayman's Avatar
Better put your flame suit on. Everone and their brother will tell you that launching this car on stock drivetrain is pretty tricky.
I can tell you that 3-4k RPM is way too low to launch with the S. You need to get it up around 5500-6000 and then SIDESTEP the clutch. This means don't ease it out, don't quickly let it out, just slide your foot off it and let it snap back up. You should get decent wheelspin, and a pretty good launch. I wouldn't do this too often, it's not good for the car by any stretch.
And no, it's not normal to smell your clutch. That means it's burning - which is a BAD thing!
Old Jan 27, 2005 | 05:24 PM
revhi's Avatar
I burnt my clutch before when my car was stock while launching. I did the 6k drop and clutchy no grabby in first or second.
Old Jan 27, 2005 | 05:47 PM
Reds2kracer's Avatar
I hear that you can feather the clutch by lauching, is this any better than just straight dropping the clutch?
Old Jan 27, 2005 | 05:49 PM
Also is too much wheel spin not good? Lauching at 6000rpm causes lots of wheel spin before you actually take off into never never land, I guess it also depends on what type of tires you have on the S as well right?.
Old Jan 27, 2005 | 05:52 PM
oOweEe's Avatar
thanx clayman!
is it true that s2k stock clutch is really weak and slips a lot?
Old Jan 27, 2005 | 06:00 PM
Bane's Avatar
hehe, this is *better* for the driveline components but absolute hell on the clutch disc.
I used to launch my turbo MR2 this way, it helped build boost and wouldn't bog the car off the line... I don't think it would be neccesary on the S2000 unless you are bogging like crazy or getting massive wheel spin.
Old Jan 27, 2005 | 06:21 PM
Well that depends if you rather replace the clutch or the driveline, at the end it all comes down to what cost less to replace...
Old Jan 28, 2005 | 01:54 AM
RACER's Avatar
Slipping the clutch like that will cause it wear out prematurely. What about the diff and the tranny?
