Smelling gas from inside cabin
Old Sep 14, 2012 | 06:44 PM
s2k-tilldeath's Avatar
Default Smelling gas from inside cabin
This morning on my way to work I could smell gas from inside the cabin. I checked on the ground and no leaks anywhere. I didn't feel any power loss. On my way home from work about 8 hours later when I walked out to my car I couldn't smell gas at all. I open the door and once I sat down I could smell gas once again. Car starts up fine and can smell gas from the inside and outside of the car while it's on. After driving for about 5 miles I noticed that when going into first gear from a stop I had to give it a lot more gas to get moving. I had to rev to about 3-4k. Any help please?
Old Sep 14, 2012 | 07:17 PM
sillyboybmxer's Avatar
gas cap malfunction (need a new one, seals are bad) or possibly the filler hose has a problem,......pretty commmon thing to smell gas with this car, typically shows itself when its super hot outside
Old Sep 14, 2012 | 07:34 PM
Ok, you think I should get one from honda or one from an auto parts store? I parked in my garage when I got home and my mom said she can smell it inside the house? I do usually get the gas cap cel every so often, but I have a habit of every few days to check the gas cap to make sure it's not loose. I'll go out and check to see if it's leaking. The whole drive home I could smell it and it was a huge smell.
Old Sep 14, 2012 | 08:11 PM
I just checked and it smells potent in my garage. Also no leaks back by the exhaust. There is something on the ground but my car isn't leaking anything out. The reservoir in the front right of the engine bay (coolant?) is empty right now. And last time I had my hood popped (2 weeks ago to check oil) it still had green liquid in it.
Oops, this one is upside down, sorry about that. This one is showing the ground that maybe the coolant liquid leaked out, and when I rubbed my fingers on it, it smelt like the gas smell.
Old Sep 14, 2012 | 10:16 PM
BrockB's Avatar
a possibility is the fuel pump assembly gasket fell off and into the gas tank.
Im not saying thats what it is, but if you know how to, then check the fuel pump assembly and make sure the gasket there is still in place.
The reason i think it might be something to do with that is because if anything is open near the assembly, then you'll smell it since it lies inside the cabin of the car, and not on the outside. and also, this happened to me before.
Old Sep 15, 2012 | 06:58 AM
TougeS2k's Avatar
i dont think it has to do with the gas cap because of the power loss, how would he lose power because of gas cap leak?
Old Sep 15, 2012 | 08:31 AM
you're right,...i didnt even see that part of the thread
Old Sep 15, 2012 | 11:38 AM
The power I lost was only going from a stop into 1st gear. It wasn't as much of a power loss as it was a "this car needs gas to get it into 1st". Once I am in 1st gear it's normal.
Old Sep 15, 2012 | 11:39 AM
You're talking about reaching it from the trunk area right? I can take that stuff apart if that's what you're talking about.
Old Sep 15, 2012 | 01:35 PM
cdelena's Avatar
Check to see if your oil filler cap is on.
