So far my N/A Build... HELP
Old Feb 11, 2007 | 11:40 AM
basslover911's Avatar
Banned
Thumbs up So far my N/A Build... HELP
Hey guys, I will be posting here my updates;
So far what I have;
- AEM V1 Intake
- Mugen Header
- Custom 2.5 test pipe
- Custom 2.5 single exhaust (has magnaflow straight through muffler)
- Apexi Vafc (not tuned, waiting to put everything on)
- Hondata head gasket (hp gains?)
What I am planning to do; (<- this is where I need help with hp figures)
- Larger throttle body (best size for n/a applications?) (hp gain?)
- Port and polish intake manifold (any hp gains with this?)
- Port and polish head (hp gains with all of the above?)
- Cams? (which ones? hp gains?)
- Spoon head gasket to raise compression (what else do I need to be able to raise the compression? I know theres about 5-7hp there (looking at JDM cars))
And of course the intake/throttle body and head machining will be done to match perfectly so the flow is good.
Anyway this is my daily driver so for practical reasons I cant go with itb's; and money!
What else would be good to produce good n/a power? Ive read almost all topics here and I think that this is the best thing to do (money to power ratio-wise) to get good hp numbers. Do I really need to get springs and retainers since I wount be doing substantial time in the high rpms?
Think I can hit 250hp?
Thanks!!
Old Feb 11, 2007 | 11:44 AM
Shadow_S2K's Avatar
Former Sponsor
With all the mods you listed that you currently have..would most likely net you around 200-210hp somwhere in the middle of that.A Good tune would make all the difference. Maybe go with the AEM EMS, the VAFC would only net you a little, to get max hp a stand alone would be better
Also are you trying to make 250hp or bhp?
Old Feb 11, 2007 | 11:46 AM
dmw16's Avatar
Im sure this has been said before, but why not just get a supercharger
Old Feb 11, 2007 | 12:41 PM
Johnny Sack's Avatar
with those mods and some good tuning you should expect damn close to 220whp. i would really recomend a 70mm exhaust as it has shown again and again to make the best overall whp.
i would recomend also getting emanage ultimate and finding a good tuner. a vafc is great but you can just do so much more with emanage than you can with a vafc.
i really think that your going to have to re-think your expectations. 230rwhp is hard to hit, let alone 250. you wont hit it without ITBS or a stroker kit.
Old Feb 11, 2007 | 02:10 PM
gomarlins3's Avatar
Good luck and I assume you mean you are trying for 250WHP. You are probably already at 250 HP.
Old Feb 11, 2007 | 05:40 PM
Banned
Yes I mean whp.
Who here has the most powerful 2.0l engine? Since I dont plan on stroking it I want to know what he/she has done to the engine...
Old Feb 11, 2007 | 05:52 PM
Luke530's Avatar
Decent header, test pipe, 70mm exhaust, then
you'll need a stroker kit, ITBs, and a good EMS tune.
that should put you over 250whp
Old Feb 11, 2007 | 05:59 PM
Originally Posted by basslover911,Feb 11 2007, 06:40 PM
Yes I mean whp.
hate to toot my own horn, but i think that i am one of the most powerful 2.0's on the boards.
ive been searching for 230whp for the last year and am 3whp off right now, looking for the right header/i've finally decided on the intake i want and that should put my solidly in the 230's but no where close to 240 or even 250whp. you'll need a stroker to hit 250.
Old Feb 11, 2007 | 06:09 PM
Banned
OK so about raising the compression!
They say that 12.1-12.5 is ok to run on 93 octane fuel...
NOW, the spoon head gasket will raise it to 11.5.1 if I well remember
BUT
What if I add pistons that raise it to the same compression (11.5.1 with the stock headgasket) AND then add the spoon headgasket... at what compression will I be at?
Like I said, trying to get hp any way I can and i think that raising the compression along with everything else should be the most power producing thing.
Old Feb 11, 2007 | 06:13 PM
BlownAP's Avatar
no need for stroke, I know of a couple cars in Socal with ITB's and beta cams that are over the 260whp with f22's...... to bad these guys are not on the boards....
Stock displacement and stock compression.
