so.. u connect the return fuel line to..
Old Aug 31, 2004 | 08:49 PM
mikecl713's Avatar
Default so.. u connect the return fuel line to..
directly to the fuel pressure regulator...
a bit far dont u think?
Old Aug 31, 2004 | 09:30 PM
AusS2000's Avatar
Eh? Didn't it come with instructions?
Ooops, my bad. Being RHD I couldn't install the FPR in the usual place so mine was installed up front on the crossmember. So I had to extend the return line. I see that the instructions say to just reroute it.
If you slide the grommet out of the intake manifold you should be able to pull the return line back to the firewall and reroute it up to the FPR. I would think the new location is closer to the point where the return goes through the firewall than stock so you shouldn't have a problem.
chubbys2k
Jun 27, 2016 07:01 PM
skibum
Dec 14, 2008 04:58 PM
scott2055
Apr 25, 2008 06:25 AM
ItalianBucwheat
Aug 21, 2002 12:15 PM
