Soft top wind noise DIY HAFLERMOD
Old Aug 18, 2016 | 08:28 PM
  #151
superstuddc27's Avatar
Originally Posted by P-CarDriver
i hope this clears it all up...if not, either i am REALLY REALLY smart or some of you are...not really really smart haha. Remember from the factory the plate goes flush against the frame, so the RED WASHER isnt there when you take it apart, thats all this mod is, adding a washer/spacer.
yea i know i forgot an S after "pull"
For some reason, the passenger/front latch is really tight on my hardtop. When I tighten it down, it lifts up the back and makes a big gap in the rear seal and I can't close the passenger door because the hardtop has slanted down and won't clear the window.
If I don't leave it latched then fitment is good. meaning, I need to loosen up the passenger front latch. Can I add a washer under the actual latch on the hardtop and not the striker to bring the two CLOSER to each other and not further apart?
white98ls
Aug 21, 2015 03:45 PM
schwett
Apr 21, 2003 07:30 PM
JL9000
Nov 4, 2002 01:42 PM
