Soft top won't operate
Old Sep 25, 2016 | 12:20 PM
airintake0_0's Avatar
Default Soft top won't operate
So I removed the engine and trans in a car, and now the soft top doesn't operate. Wondering if somebody knows why. I figure I lost a ground or something somewhere, but not sure. Any insight is appreciated.
Edit. the motor and trans are still on the ground, I just want to operate the top. So the wiring under the hood is just hanging there.
Old Sep 25, 2016 | 12:33 PM
windhund116's Avatar
I know this is a dumb question --- pardon me --- but, did you remove the battery, when you pulled the engine?
Old Sep 25, 2016 | 01:31 PM
The battery was disconnect. but left in the engine bay.
Old Sep 26, 2016 | 05:17 AM
9KEVERYDAY's Avatar
Check the little wire that connects to your Ebrake handle underneath your center console.
Old Sep 26, 2016 | 07:21 AM
You have parking brakes on?
Old Sep 26, 2016 | 12:04 PM
Chuck S's Avatar
The roof won't operate unless is also reconnected. With the engine out beware of loose wires.
-- Chuck
Chuck S's Avatar
-- Chuck
Old Sep 26, 2016 | 12:28 PM
Ap2low's Avatar
Are your windows going down when you press and hold the top button?
Old Sep 27, 2016 | 01:45 PM
there is nothing happening, I believe it must be the fact that the vehicle speed sensor is not telling the module the car is stationary. I may slide the tranny back under and find out.
Old Sep 27, 2016 | 01:47 PM
Yes its on and the light on the dash goes on and off
