Someone help before I jump ship
2002 103k miles. Ap2 trans with 90k miles. Comp stage 2 clutch. Oem flywheel. Aem intake. Everything else stock. Fresh synchromesh
Hey guys need some help.
S2k shifts beautifully every gear. Any rpm. Any speed. Except 4th. Shifting into 4th is a dream. But when I try shifting at 9k to 4th, it hits a brick wall. Doesn't grind. Doesn't make any noise. Just simply won't go into 4th until rpms drop to around 6. Tried adjusting clutch, made no difference.
Also another weird thing if I'm stopped, I can go I to any gear aside from fourth. If I'm in light, press clutch and try to shift to 4th it won't go. Any other gear is fine. If I shift to third first then 4th without letting go of clutch it's perfect.
I'm just lost. I don't think its synchro because it doesn't grind, it basically just acts as if there is literally a wall between 3-4.
Things I tried but didn't work:
Gm synchromesh
Adjusting clutch
Regreasing shifter.
Oddly if the trans is cold it doesn't have this issue. HEELLP ME.
Gm synchromesh
Adjusting clutch
Regreasing shifter.
I was going to look for a similar post from Billman! Great advice and probably a good place to start.
Is this a recommended procedure every now and then for pro-active maintenance to keep gear collars in shape?
