something has to be wrong with my trans
I would change the tranny fluid with Honda MTF, bleed the clutch fluid with lots of fresh DOT 3 brake fluid, and change the differential fluid with LE 1605, M1 75W-90, or AMSOIL SVT 75W-110. I really suspect that it is your clutch that's the problem if you are having trouble getting into gears though.
I would try changing the clutch and trans fluid. I've got 170k on my stock trans/clutch and sometimes the 1st and reverse are a little difficult first thing in the morning. I usually slide it into 2nd before trying 1st or reverse. I used to have a grinding issue in 2nd when it was hot, but that went away when I started using Redline MTF. Good luck.
In addition to a fresh load of MTF, check the clutch to make sure that it is disengaging fully. The clutch hydrolics might need bleeding. hello.gif
Originally Posted by sbrodacz,Jun 2 2008, 07:27 PM
how do I do that?
I wonder if I should try redline then....
I'd try a fresh load of Honda MTF before looking at alternatives, simply because it works well for most S2000's.
