sounds like water
Old Dec 12, 2011 | 12:12 PM
har-vey's Avatar
Default sounds like water
i have an odd sounds coming from the front of the car, it sounds like water. i dont know how else to describe it. it only happens when i put load on the car (so as i bring the car to biting point) does anyone know what this could be?
Old Dec 12, 2011 | 08:25 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Clogged ac drain. There's water sloshing around in the heater box.
Old Dec 13, 2011 | 12:21 AM
wrecked's Avatar
If that's what it is, you can un clog the A/C drain by shooting compressed air in the tube. Also, you better do it quick or it might leak out into your carpet and get it all moldy. You will know it was clogged if you blow air in the A/C drain and water pours out for like 10 seconds.
Old Dec 13, 2011 | 02:27 AM
har-vey's Avatar
where would i find the A/C drain hole?
Old Dec 13, 2011 | 04:38 AM
Billman250's Avatar
Top Answer: 1
Under the car. I'm pretty sure it's right next to the exhaust header. It a black tube coming out of the firewall, about big around as a quarter, and it points straight down towards the ground.
Old Dec 13, 2011 | 04:46 AM
har-vey's Avatar
thankyou i will have a look later on. are there any threads on how to do this/ any pictures to help
Old Dec 13, 2011 | 04:51 AM
Billman250's Avatar
Top Answer: 1
Not that I know of...
You wont see it till you are under the car, Looking up at it.
Use ramps, set the ebrake. This is safe.
Old Dec 13, 2011 | 05:06 AM
zeroptzero's Avatar
you may need to stick a pipe cleaner up the drain tube once you locate it. The tube is right beside the header on the passenger side of the firewall just near the frame.
Check if you have water in the doors, move the doors back and forth and see if water sloshes around. I had that happen on a previous car where the drain holes were plugged with rustproofing spray. There is also common leak point in the rear air vent that can allow water to pool in the floor of the trunk under the spare wheel and trunk cover, if you are hearing the water noise towards the rear of the car.
Old Dec 13, 2011 | 05:58 AM
har-vey's Avatar
i can only hear it when i am on the throttle
Old Jan 5, 2012 | 03:54 AM
har-vey's Avatar
so i got the car on the ramp and blew air up the drain pipe. made i nice clinical smell in the car but no water rushed out is there anything else it could be?
