Spark Plug Change
Old Aug 1, 2007 | 12:40 AM
iam7head's Avatar
Originally Posted by turboti9er,Jul 31 2007, 09:41 PM
OEM Honda plugs are Denso Iridium plugs, you can order them on ebay or from Honda, they have to be iridium. 35k? OEM plugs last you till 100k miles, you don't need to change it unless something is missing that your not telling us.
wrong wrong wrong and wrong
Old Aug 1, 2007 | 08:24 AM
VAD's Avatar
VAD
Old Aug 1, 2007 | 11:40 AM
hirev's Avatar
what makes you think you need to change plugs now????
Old Aug 1, 2007 | 03:42 PM
doheboy6's Avatar
sparkplugs.com
Old Aug 1, 2007 | 06:26 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by SenderGreen,Jul 31 2007, 11:18 PM
Honda part# 98079-571BH
That is the way to go.
This plug is tailored specifically for the S2000, by NGK.
Gapped to exact spec, THEN platinum coated. This plug can only be bought from HONDA. NOWHERE ELSE.
Adjusting the gap on a platinum plug can fracture the coating and cause the plug to fail.
Even if you get the correct NGK part number, they are not the right gap. Go ahead and check for yourself.
Old Aug 1, 2007 | 06:27 PM
Billman250's Avatar
Top Answer: 1
And yes, there is definitely no reason the change them now, unless you were below the recall point. Not sure when that was....
Old Aug 1, 2007 | 06:39 PM
Mister Jew's Avatar
I know they can last until 100k but, ahh i dunno i just usually change my plugs alot earlier always? I also checked at the dealer that my plugs were replaced under the recall dont remember the date. I guess ill leave em for now. The car runs fine though so ya thanx for all the info guys.
Old Aug 1, 2007 | 06:48 PM
Billman250's Avatar
Top Answer: 1
I would:
Take at least one out, and make sure thay are PFR7G-11s NGK plugs.
Make sure they are torqued properly. Loose plugs can do major engine damage.
Old Aug 1, 2007 | 07:35 PM
SimpleMan's Avatar
Can you put in the standard copper NGK BKR6E? All 3 of my other 4 cylinders run those so that would be super convenient for me seeing as I have 8 of them in the garage. I believe thats what they run in type R's
Old Aug 2, 2007 | 04:14 AM
INDYMAC's Avatar
I just changed the OEM platinum plugs on my 2003 G35 with 65K miles because a recent UOA showed fuel dilution and low flashpoint. The plugs were pretty well shot (down to nubs) and one coil and plug came out soaked with oil. I had to replace the valve cover just to replace the hardened/defective o-ring seal for that spark plug tube.
Recommendation? Check your plugs before the manufacturer's drivetrain warranty is over. I wish I had. And, as Billman stated, use the Honda OEM plug. The proper gap is critical and will allow for complete combustion. Fuel dilution ruins your engine oil very quickly too.
