Spark Plug change DIY
I tightened mine up today, they were in the car for about 2500 miles, I installed them at 18 ft lbs. They turned a small bit at the new tightening spec., but they weren't loose. Number 3 plug turned a bit more than the others for some reason. Thanks for the info Billman and Jordan
Copper is actually a better conductor of electricity than platinum or iridium, the thing is that they wear faster. To be honest the price difference between platinum and iridium plugs are non-existent and factually iridium plugs should last longer.
I remember reading that in addition to better geometry, iridium (and platinum) as a material sparks more easily but I currently can't find it online.
When I changed my plugs last time, I went for iridium ones, because as you said the price was close and the iridium plugs should last longer.
