Spark Plug change DIY
Originally Posted by chemr16,Apr 26 2010, 03:52 AM
non s2k related but my buddy changed his and said his plug was covered in oil...anyone know what that means?
my guess was that he should thoroughly check the injectors to see if there were any tears or holes in the rubber seals on the injectors...am i correct on this?
Plan on doing this over the upcoming weekend. Had to get the spark plugs ordered from Advanced Auto. Seems most S parts are never in stock. Came to $42 and change with tax. I'll report back after the work is done!
Did the replacement yesterday. Took all of 30 minutes, and that was working very cautiously. Overall a very easy thing to do, especially with this write up. Thanks OP!!!
My old plugs were a light brown. Original ones on the car, an 05 with 61k miles on them now. Should be good to go for a while.
Originally Posted by ans2k,Jul 12 2010, 07:59 AM
often? simple answer is no.
Originally Posted by Reckon,Jul 14 2010, 03:43 PM
Got it. Should they be replaced at all as a preventative measure in anyway? Been trying to find information it. I only read about them being replaced when there is a misfire or a spark issue.
but, the only time people would replace them is b/c they are bad or they are FI (upgrade). just make sure you tighten the spark plug to 20 ft-lbs. yea sure 18 is what the specs say but if you want to make sure 20 it is.
