Spark Plug Cover
DO NOT use brake fluid!
Use the correct penetrating lubricant like PB Blaster or Liquid Wrench. Also, it really helps to use a hex bit mounted in a 3/8" drive socket rather than the typical L-shaped hex key.
Originally Posted by Spookee,Apr 30 2007, 10:04 AM
try some brake fluid around the bolt... that usually works. **************BE CAREFUL THO**********
if you drop some on the valve cover or anywhere on the body it may ruin paint
redap186
44
Aug 21, 2020 10:18 AM
CynicG
Feb 14, 2017 02:47 AM
