Spark Plug non fouler
Old Feb 2, 2008 | 12:57 PM
rikhemi's Avatar
Default Spark Plug non fouler
Quick question,
Just installed an invidia 60mm testpipe and two sparkplug non foulers. Ive read that this leans out the car a bit, is this true.
Thanks
Old Feb 2, 2008 | 01:32 PM
sharptech's Avatar
I installed the non fouler and noticed no change in afr or egt's. was 13.7 after 13.7...so answer would be no.
Old Feb 3, 2008 | 06:20 PM
Fastblack2K's Avatar
All the non foulers do is make the O2 sensor sit further out of the exhaust stream than it usually would. This is to replicate the airflow it would see when a cat is on there. If you took the cat out and left the O2 sensor as is, it sees the increased airflow, and richer a/f so it reads that as low cat efficiency, and throws a cel. Thats the point of the secondary O2, the primary O2 is used to adjust the a/f. So now that I took the long way around, simply put, no it doesn't affect your a/f, just saves you from a cel which can affect many things.
Old Feb 3, 2008 | 06:59 PM
Jacko's Avatar
I'm no expert but the tuner I talked to said YES the test pipe will change your A/F
but the only way to tell if your car is running lean is to measure your A/F
FYI I have a PLXS A/F gauge and the test pipe does change MY A/F range and DID lean
it out
But as Flashback stated above the Spark Plug Non Fouler itself will do nothing to your A/F range it only fools the Secondary O2 sensor so your CEL doesn't come on
Old Feb 4, 2008 | 06:31 AM
rikhemi's Avatar
Ok, thanks for the responses. Ive read in the s/c forums that it does change it but I wanted to make sure.
By the way, I have the 60mm invidia testpipe. I wanted to use the old cat cover to put around the testpipe. Do you guys agree that the best thing to wrap around the testpipe would be some header wrap so that the cat cover doesnt rattle.
Old Feb 4, 2008 | 06:17 PM
Jacko's Avatar
sorry bro I don't have any advice on your cat cover question because I just have the test pipe no cover or header wrap.... but then again my header isn't wrapped either
I don't like the way it looks I know its not the best for performance but I'm willing to sacrifice a couple of ponies I keep thinking about the gel coat but haven't gotten around to it but anyway if your going through all that trouble I would try and just get it welded I would think that would take care of any rattles good luck
-Mike
cjts2000
Sep 21, 2017 06:21 AM
s2kfrog
Jan 6, 2009 08:15 AM
attack666
Aug 16, 2007 02:42 PM
Nate03
Jan 1, 2007 08:53 AM
mytse
Jan 26, 2006 04:54 AM
