Spark Plugs
Originally Posted by flblue,Sep 29 2008, 11:48 AM
There is nothing connected to the plug end????
Once the cover is opened, can you simply use a socket to unscrew the plugs?
mechanic<<< never broke a spark plug<< use pb blaster... its made for metal and probelms like that.. u can get it at any pepboys.... its sorta like wd 40... but better for rust and such... once u get them to losen a bit.. go back and forth tight and lose.. so you dont strip the threads
Shock is always better than constant pressure. Otherwise high chance of stripping the spark plug or cross threadding and ruining the thread.
So make a nuckle and hit the wrench with it couple times.
Just in case.....
Lefty Loosy Righty Tighty.
So if the ratchet handle is pointing towards the windshield you wanna shock it towards the psgr fender.
Good Luck.
Just in case.....
Good Luck.
zeroptzero
Oct 14, 2009 04:32 PM
