Sparkplug, colder heat range
Old Feb 10, 2005 | 11:29 PM
RT's Avatar
RT
Default Sparkplug, colder heat range
Sorry for the x-post but didn't have much luck in the FI forum. Hoping for more exposure/answer one step out
Originally Posted by RT' date='Feb 9 2005, 10:16 PM
What's the closest match to the stock NGK but one heat range colder ("8")?
I know people are running Denso IK24's but how about a double platinum NGK in a #8 range instead of an iridium or any other wacky a$$ shiz .......
Stock NGK PFR7G-11S description:
14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, projected tip, extreme long life double platinum, fine point platinum on center electrode, platinum tip laser welded on ground electrode, Stainless steel washer reduces plug self-backing. .044"gap
BTW, search function down
Old Feb 11, 2005 | 04:21 AM
Slows2k's Avatar
A non-platinum NGK is a R5672A-8, or NGK Stock # 7173. I Never used a platinum plug with the SC. The copper core plugs are cheaper, and don't have a very hot fine wire electrode.
Old Feb 11, 2005 | 04:47 AM
Gernby's Avatar
Former Sponsor
Why do you want Platinum over Iridium? My understanding is that platinum trades performance for longevity when compared to copper, but the iridium adds the performance back in.
Old Feb 11, 2005 | 08:51 AM
RT's Avatar
RT
sweet, any problems w/ them not being resistor type?
Old Feb 11, 2005 | 08:52 AM
RT's Avatar
RT
sorry, no time to bench race right now maybe later
Old Feb 11, 2005 | 03:29 PM
Slows2k's Avatar
No increased RF noise heard over the radio, never had a misfire. I give them For price and peformance.
Chances are if you are swapping to a colder plug, you'll be pulling them regularly to check them anyway. At the replacement costs of a set of copper cores, why not swap with new every time you check? You can replace them 4x and be $$ ahead over what 1 set of iridiums or platinums cost.
A fresh plug of any type gives better performance than a many thousand mile plug.
Old Feb 11, 2005 | 05:15 PM
RT's Avatar
RT
Thanks Slow, picked a set up at lunch for $1.99 per ...... nice
KaNgArOo
Feb 22, 2015 10:55 AM
VAD
Apr 30, 2010 04:13 PM
S2Kage
Feb 8, 2009 08:20 AM
macspeed704
Nov 10, 2005 08:06 PM
Wael El-Dasher
Dec 13, 2004 06:48 PM
