sparkplugs
They are neatly concealed under the black plate on top of the valve cover. You will need an allen wrench to unfasten 6 bolts then lift up the black cover. Underneath the plate you will see individual coals on top of each spark plug. These have a bolt you must loosen first. Then you can access the plugs. I can take my plugs out, inspect them and re-torque them in about 10 minutes.
John
John
Be careful with the allen bolts if your motor is still hot. They will be harder to take out and will strip easily. Also, on my car I only have 4 allen bolts that holds the cover onto the head.
XV, I wish I had read this before I struggled to get that cover off! (Doh!!) Next time I'm going to do something on my car, I'll post here a few days in advance and save myself some bloody knuckles and frustration.
jd
jd
