sparkplugs
Old Jul 10, 2002 | 05:09 PM
robb's Avatar
Default sparkplugs
I got my first in person look at a s2k engine and couldn't see the plugs or wires I assume they are under the cover near the v.c ? Are they hard to get at? TIA
Old Jul 10, 2002 | 05:53 PM
John MI blk/blk '01's Avatar
They are neatly concealed under the black plate on top of the valve cover. You will need an allen wrench to unfasten 6 bolts then lift up the black cover. Underneath the plate you will see individual coals on top of each spark plug. These have a bolt you must loosen first. Then you can access the plugs. I can take my plugs out, inspect them and re-torque them in about 10 minutes.
John
Old Jul 10, 2002 | 05:57 PM
Chazmo's Avatar
This process is well-documented in the owner's manual, robb. I agree with John that it's about a 10 minute job. Be careful not to get your socket wrench stuck down the hole
Old Jul 10, 2002 | 07:58 PM
xviper's Avatar
Duct tape the plug socket to the rachet extension - problem solved.
Old Jul 11, 2002 | 10:22 AM
Chazmo's Avatar
XV, you da' man. That's a totally great idea. i never thought of that -- d'oh!
Old Jul 11, 2002 | 11:07 AM
SilverSurfer's Avatar
Be careful with the allen bolts if your motor is still hot. They will be harder to take out and will strip easily. Also, on my car I only have 4 allen bolts that holds the cover onto the head.
Old Jul 11, 2002 | 11:44 AM
xviper's Avatar
[QUOTE]Originally posted by SilverSurfer
[B]Be careful with the allen bolts if your motor is still hot.
Old Jul 11, 2002 | 11:59 AM
johnnydev's Avatar
XV, I wish I had read this before I struggled to get that cover off! (Doh!!) Next time I'm going to do something on my car, I'll post here a few days in advance and save myself some bloody knuckles and frustration.
jd
Old Jul 11, 2002 | 12:45 PM
xviper's Avatar
[QUOTE]Originally posted by johnnydev
[B]XV, I wish I had read this before I struggled to get that cover off! (Doh!!)
Old Jul 11, 2002 | 01:24 PM
Meyer's Avatar
What's the size of the plug socket?
