specs for 4.77 ... how should everything be set?
I pulled my differential down because I had my 4.77 installed and they where whinnying a little. what are the specs that everything should be set to? I had the sheet from motorklasse but I lost it.
thanks
thanks
.003" is the factory spec. right in that range, 3 to 5 thou.
use google, and type in... "ring and pinion lash setup"
youll get some good stuff, from richmond gear and drivetrain.com
check them out, gives you an idea of whats entailed. good luck. dave
Originally Posted by chillout18,Aug 26 2007, 09:39 PM
i thoguht they are suppose to be set tighter ?
https://www.s2ki.com/forums/index.php?showtopic=509497
There is a lot of info there on setting up gears. Spitfire s is a good guy to talk to.
