Speed Bleeder thread sealant: any alternative?
Old Jun 15, 2004 | 07:55 AM
  #21
rlaifatt's Avatar
[QUOTE]Originally posted by krazik
Old Jun 15, 2004 | 07:57 AM
  #22
krazik's Avatar
Administrator
I too have switched from ATE to Motul. It's better fluid.
But a bleeder screw should not care what fluid is run.
Old Jun 15, 2004 | 07:58 AM
  #23
Voodoo_S2K's Avatar
[QUOTE]Originally posted by Asura
Voo, next time use the cheap stuff until the pedal is stiff and then use the ATE until it bleeds blue.
Old Jun 15, 2004 | 08:00 AM
  #24
Voodoo_S2K's Avatar
[QUOTE]Originally posted by rlaifatt
I've noticed that ATE appears to be less viscous (seems like water) compared to Motul 600 that I use. I wonder if this could be a reason Speedbleeders don't work well for some, i.e. people using ATE.
Old Jun 15, 2004 | 09:04 AM
  #25
Asura's Avatar
[QUOTE]Originally posted by Voodoo_S2K
Old Jun 15, 2004 | 09:25 AM
  #26
rlaifatt's Avatar
Old Jun 15, 2004 | 02:49 PM
  #27
krazik's Avatar
Administrator
I can't imagine there is a significant difference in viscosity of brake fluid. They all seem to pour the same and brake fluid isn't designed for viscosity its designed to not compress and not boil.
Old Jun 15, 2004 | 04:13 PM
  #28
alexf20c's Avatar
Why do you need to bleed your brakes?
Old Jun 15, 2004 | 05:16 PM
  #29
nsx555's Avatar
Originally posted by Road Rage
The hardest pedal I have got on my older cars has been a reverse bleed from the Phoenix Systems V-12. It pushes the air where it wants to go - up.
RR,
I guess you haven't used this yet on your S since it's so new, but do you think it would do a good job on the S.
john
Old Jun 15, 2004 | 08:47 PM
  #30
alexf20c's Avatar
Vacuum bleeders suck.
robb
Apr 28, 2016 12:11 PM
street_ruler
Mar 13, 2012 09:19 PM
Smokee
Nov 11, 2005 08:23 PM
GSi
Nov 4, 2004 07:29 AM
