speedcraft
Old Oct 20, 2002 | 09:18 AM
bosS2000's Avatar
Default speedcraft
does the v-afc help out a good deal?
Old Oct 20, 2002 | 09:44 AM
TurboVtk's Avatar
Have not experienced it first hand but i have read that it does work a hell lot
Old Oct 20, 2002 | 10:35 AM
iLikeBeer's Avatar
what the hell does that have to do with speedcraft?
Old Oct 20, 2002 | 11:04 AM
Thoe99's Avatar
maybe he meant "does the vafc help with the speedcraft kit"
Old Oct 20, 2002 | 11:28 AM
cjb80's Avatar
In response to "Does the VAFC help with the Speedcraft kit?" question, the answer is yes, but barely. All it will help do is smooth the fuel map. I think the kit with just the fuel pressure regulator on it will make the car run really rich in boost.
The problem is that the VAFC doesn't detect boost levels, so therefore it assumes that if you're at full throttle that you're at full boost. Areas in between are kind of guesswork. It's a very basic setup, and it only controls fuel.
The optimal soltion would be to go with a setup like an EMS.
Chris
Old Oct 20, 2002 | 07:31 PM
Thoe99's Avatar
How's your car going by the way, CJB80? I've read your other threads about your turbo install.
Old Oct 21, 2002 | 04:56 AM
derryck's Avatar
Just barely.... Chris, c'mon man I picked up about 40 RWHP with dyno tuning using the V-AFC after the initial install on my car. I was only getting about 240 RWHP initially and with the V-AFC we got it around 280 RWHP... not what I would call 'barely'. I picked up about 8 RWHP with a bone stock car by adding the V-AFC.
Old Oct 21, 2002 | 05:44 AM
cjb80's Avatar
In comparison to other piggy backs and also in comparison to stand alones the VAFC is very weak. I wasn't aware of how much power you picked up, that tells me that the fuel pressure regulator is not tuned very well at all.... (It's 12:1, perhaps it should be calibrated to deliver less fuel...)
Chris
Old Oct 21, 2002 | 07:33 AM
derryck's Avatar
It was okay up to the point of VTEC engagement but was incredibly rich after VTEC... after raising VTEC and taking out considerable amounts of fuel above VTEC everything seemed fairly well tuned.
Gernby
Nov 8, 2010 12:10 PM
WalkingDrunken
Sep 20, 2004 03:45 PM
daniel leproe
Jan 14, 2004 12:05 PM
payyourtoll
Apr 30, 2003 02:10 PM
Yellow Streak
Dec 10, 2002 12:31 PM
