Speedometer conversion
I have recently imported a 2004 S2000 from Japan, and have almost completed the UK conversion.
The problem I have is that the speedometer is rated for KMH only. The UK speedometer does both via a switch. The switch is in place, but they have craftily disabled it. Has anyone been able to enable the switch?
I have purchased a converter chip which just multiplies the speed sensor signal to output miles, but would prefer to get to the root of it and enable both.
A new PCB panel from Honda is over
USDM cluster for an 04 only goes to 8k RPM (US is the only one who got the 2.2L if I am not mistaken). You would have to use 03 or older. I don't know if the connectors match?
I was actually thinking of trying to find a European '04 cluster with the 9k tachometer to put it on my car! I miss those 1000RPM's soooooooo much!
